| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83512 09/28/2007 5:10 AM | Joined: Apr 2007 Posts: 30 Apprentice | | Apprentice Joined: Apr 2007 Posts: 30 | I have a couple questions about my Carter W-1 carburetor. The metal tag has "839987" which I guess is Chevy's part number for the 574s. The tag also has "K7"; a tiny cut-out shaped like the clubs symbol from a deck of playing cards; and another tiny cut-out of two diamond shapes side-by-side. What does all that mean? Also, the float bowl doesn't have a "C" for Chevrolet; it has "RPD". What does that mean? Is this 574s somehow different than the 574s made by Chevy? (carbking, are you out there???) Thanks for any help with this! Dale | | |
#83513 09/28/2007 12:16 PM | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Dale - you stumped me.
Not 100 percent sure of the meaning of "RPD". In times past it has been explained to me by self-annointed experts that RPD meant "replacement parts division" OR "Rochester Parts Division". I have never seen a definative answer on a GM document; so it might mean one of the above OR it might mean something else. And since I don't know, I won't speculate on the meaning, although I have my own opinion.
The "K7" is a date code meaning either the 10th or 11th month of some year ending in 7. Since the 574s was not produced as a service carb (the 684s was used as the SR), the 7 probably represents 1947. This is the typical A=January, B=February, etc., etc. code. The reason for the vagueness concerning 10th or 11th month is that in some years the letter "I" was used, and in some years it was omitted.
The "cut-outs" were inspector stamps. I do not have a cross-reference of the stamp code to the stamping inspector.
Bottom line is this is one of the Chevrolet (or GM) produced carburetors.
And I apologize for the incomplete answer. While our library of Carter (as well as other original carburetor manufacturers) information is pretty good, we have less complete information from the car manufacturers (except for Pontiac and Oakland).
Perhaps someone else will have "RPD" on a GM document such that we may all learn the exact meaning of RPD.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#83514 10/03/2007 3:50 AM | Joined: Apr 2007 Posts: 30 Apprentice | | Apprentice Joined: Apr 2007 Posts: 30 | Jon - Thanks for the reply and the date code info. I poked around on the internet and found a number of references to the "Rochester Products Division" of General Motors. But I didn't find anything related to Carter. If the "C" carbs where produced by Chevy (at their Bay City plant) maybe the "RPD" carbs where produced by GM at another location? | | |
#83515 10/07/2007 6:10 AM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Maybe Rochester Products Division, since it was called Rochester Products? | | |
#83516 10/07/2007 10:37 AM | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'm getting a little cornfused here Jon. I've been searching for a couple of days also for Carter history and can’t find anything that indicates that GM produced Carter carburetors. They of course used them as original equipment like Ford and Chrysler did. Also Rochester Products Division was formed after the era of the W-1 wasn’t it? And again did RP ever manufacture carburetors under contract from Carter? Also the Bay City plant 'C' that is mentioned was seen on the Rochester 'B' model carburetors after it was acquired by GM wasn't it?
Sure is a lot of "weren’ts and wasn’ts" on this one. Denny Graham Sandwich, IL
Denny G Sandwich, IL
#83517 10/07/2007 7:11 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | I thought the Bay City "C" carburetors were a Chevrolet copy of the Carter W-1, and were in no way related to to the much later creation of Rochester Products Division from North East Electric Company. I don't know if Chevrolet made them under license to Carter or not. | | |
