8 members (Otto Skorzeny, 68ironhead, 3B, Jon G, Gdads51, NJC, 2 invisible), 104 guests, and 1 robot.
Topics128,130
Posts1,056,369
Members48,441
#834918 03/13/2012 5:09 PM
Can anyone recommend the proper 12 volt coil for a 1954 GMC (248 motor) that has been coverted to 12 volt? Thanks.
Standard points ignition?
Are you now using a ballast resistor between the ignition switch and the coil?
yes I have the balast resistor....
Yes I am....
Smithleej,
Well i see you and i have the same truck and motor (248)i also am in the middle of trying to convert my 6v to 12 and need all kinds of advice. I am by no means any sort of electrician and find everything i read about it a little more confussing. I have purchased a new powermaster 10 (si) alernator, voltage reducers and all kinds of stuff. I will probably get someone with electrical automotive expierience to hook it all up because i cannot afford to do the smoke test at this point. I am learning everything as i go and if i can help you just let me know and i will if i can. Welcome to the Bolt.
Wes
