6 members (delky, J Lucas, Samantha, rick46ia, crenwelge, KEVINSKI), 122 guests, and 5 robots.
Topics128,261
Posts1,058,342
Members48,485
I would like to get this 4 speed tran. up to speed. It is just geared to slow to go from town to town an stay with the group I would like to go with. I have a 1 ton 48 chev panel and the first gear will not get me across the street. Do you know what is in the truck and what I should go to. Thanks for your help.
Your truck probably has a SM420. The final ratio is 1 to 1 so changing the transmission out would require a transmission with overdrive. It has been talked about many times here and if you do a search you'll find lots of discussion about it.
Also consider axle gears and or a whole newer rear axle. Taller tires also help with speed.
•1952 Chevrolet 3800 pickup
---All pictures---
The 4.10 rear differential from a 67-72 truck that used the same "banjo" style axle will improve your top speed significantly. 1-tons came from the factory with 5.14 gears.
1954 GMC De Luxe COE
Here's a good gear and speed calculator
http://www.onlineconversion.com/bigger_tires.htm
---All pictures---
