8 members (Jay R, Gray_Ghost, WICruiser, Greg_H, Otto Skorzeny, Wheelie, 1955 1 Series, Napco Man),
149
Mod | | | Forums66 Topics128,083 Posts1,056,080 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Tried looking through previous posts, but couldn't find a definite answer. Does any one have part numbers for roller bearings and seals for 1/2 ton AD trucks? Hoping I can pick them up at NAPA or one of the bearing houses locally. Thanks. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Napa probably can't help. They are one-offs made by MBS Bearing out of Japan. Most of the vendors out there have them availible, though. Try www.classictruck.com , they seem to have the best prices, I've found. Chev's of the 40's and Jim Carter probably have them too. | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | They are no longer made by MBS. I believe the MBS bearings are superior to the chinese roller bearings. My 59 gmc 1/2 ton went through 2 complete sets of the chinese bearings. The bearings ended up destroying my spindles forcing me to find a new front axle.
Inner seal: National #6064 Inner bearing and race: MBS #909052R Outer race: Timken #LM11919 Outer bearing: Timken #LM11949 | | | | | Joined: Nov 2011 Posts: 139 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 139 | Thanks for the info. Now to sort through the disc brake conversion options. Might as well do it all at one time. | | | | | Joined: Dec 2010 Posts: 291 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 291 | Imho I would install newer roller bearings with the disk brakes. Good luck on your parts Quest.
Mike | | |
