| | | Forums66 Topics128,009 Posts1,055,297 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2011 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 78 | I am installing a rebuilt 235 in my '46 6400. It has the following sequence adjacent to the distributor: FII4B and there is also this: con 3 A 139 It is the 3764476 block which could have been made in several years so really only for my own education can someone tell me what any of the rest means. I know the F is Flint but I am not finding some of the codes defined.
Thank you in advance for your help. LevisPop
Milk the cows you have
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Looks like you have a '59 Passenger 235, originally hooked up to a Powerglide. Appears to be a January 13 1959 casting date, with a January 14 1959 assembly date. If it is still running the original or stock replacement cam, it should have hydraulic lifters.
Bill Burmeister | | | | | Joined: Oct 2011 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 78 | Longbox55: Thanks, actually it came out of a 1948 6400 truck. I had the block checked out and machined. It will be put in my '46 6400 with solid lifters. I reused the cam which was in excellent shape. My biggest question now is: did you get that detail from the 3 A 139 on block? If so, please explain how the code works or point me to where I can understand this stuff. You see, I thought the B in the code by the distributor indicated the block being a truck block. Just trying to understand. Thanks so much.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | CON 3 supposedly means Conveyor #3
A 13 9 A = first letter in alphabet = first month = January 13 = day of month 9 = 1959 (the 1949 235 engine is different and there was no 1969 235)
Will you be using new solid lifters? Maybe someone will comment on a recommended break-in procedure?
| | | | | Joined: Oct 2011 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 78 | TIm, Thanks. Since this engine was rebuilt at some previous point in its life and was pulled from a '48 truck I don't think I am doing anything too "out there." I have put it back together with copious amounts of assembly lube and am planning on running Joe Gibbs oil in it for the first 500 or so. Any additional tips from you or anyone are sure welcome. Okay, and now how about the other code by the Distributor? The F is Flint, what about the II4B??? If this indicates the "build" date as January 14th then what does the "B" indicate? Blessings to all,
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | "B" is the application code. In this case, Passenger car with Powerglide transmission.
Bill Burmeister | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I belive the info Longbox gave you is correct. Did it have hydraulic lifters in it?
I would be concernced about running a new set of solid lifters against a hydraulic cam, (if that is the original cam) as I understand it you could be in for a short cam life. Do a search here for "hydraulic lifter cam" and you'll find quite a few threads on the subject.
Good luck. | | | | | Joined: Oct 2011 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2011 Posts: 78 | Thank you, one and all. I will look into this cam issue. I sure love Stovebolt!!
