1 members (J Lucas),
85
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 6 Member | | Member Joined: Jul 2004 Posts: 6 | Hi all, I am new to this site and I love it. Can anyone help me I am 22 and new to the '50s. I am used toworking on newer stuff and PRE '30s engines. I just picked up a 1952 3100. Can anyone give me info on engine and tranny options so I can figure out what I have? Also and good websites that might have info and specs on the truck, engine, trans, etc. Thanks Speed | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | Speed, your '52 will probably have a 216 cubic inch Babbit-bearing engine. Some of the regulars here have a wealth of knowledge on options and original-equipment information. I've got several old manuals from Motor Magazine, covering automotive applications from 1940 through 1971, and I'm sure the trucks share some of the same equipment and specifications as the cars. Your engine size will be stamped on a machined pad near the distributor, and there are several casting numbers on the block and head to help identify exactly what you have. You're right, this is a great site! Jerry
| | | | | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | speed5105 you will want to go to the FAQ page or the tech tips or just do a search for restoration packet. There should be a number to call GM and they will send you a packet for FREE. It has alot if not more then all the info that you are asking about.
Welcome to the STovebolt Page! Have fun!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Jul 2004 Posts: 6 Member | | Member Joined: Jul 2004 Posts: 6 | Thanks For the help guys! Speed | | |
