1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#834257 03/11/2012 5:13 PM
ODSS President
ODSS President
I've had the Newport electric wipers in my daily driver for a year now but plan on adding these parts together with a Mason jar and a couple squirter heads for the w/s.
Parts seen here.
The switch is an intermittent (delay on-off for misty conditions) with two speed wipers and washing function. Anyone have a wiring diagram for the multicolored pigtail?
I plan on using the stock '49 wiper switch with some help from a magician-machinist friend.
The black cylinder is a generic w/s washer pump.
~ Cosmo
1949 Chevy Half Ton
I did a little poking around and found this The wiring diagram is about a 1/3 of the down on the page. The part number on your box matches the diagram.
Dale
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
ODSS President
ODSS President
WOW!!! Thank you so much. I internet surfed for a couple hours and couldn't find it. Probably would have guessed correctly as I already have the two speed electric installed.
I really appreciate your effort.
Thanks again,
Cosmo
~ Cosmo
1949 Chevy Half Ton
