| | | Forums66 Topics128,068 Posts1,055,882 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | I have a 59 fleet with the original 235. It's a great motor and I have no complaints. That said I have found a 265 that has been rebuilt and came out of a 55 vette. Were 265 engines an option in the 59 fleets? I'm kind of a original look guy and I think the 265 was an option but I'm just not sure. It also comes with a two speed powerglide but I want to keep my four speed manual tranny. Is this easy to do? Also I have added the Patrick's 3:38 kit. Will this be a good option for the 265 or would I have to change it out to something else? Any thoughts or help you can offer would be great. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Joshm, in Canada the V8 engine was an option in trucks from the 55"B" or 2nd series on, 283s were used starting in 57. I understand that in the states the 265 V8 continued to be used up until at least 1958. I have no idea if the V8 was an option on "fleets" as we did not have them in Canada. If you want to swap in a V8 it is fairly simple once you purchase the parts to do so, a front engine mount kit available from many aftermarket suppliers, a truck V8 bellhousing, and a kit for throttle linkage, there was a fan shroud on the original V8 trucks, so that might be required as well, hope that helps. | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | If that's a correct-number 55 Vette engine, cylinder heads and all, it would be worth enough to a restorer to finance a pretty good buildup on a 350, or another late model engine with more power. The 55 model 265 is unique, since it does not have an oil filter location on the block back by the bellhousing. 56 and later engines had an integral filter. 55's used a bypass filter mounted up by the intake manifold. Those blocks are extremely scarce. Jerry
| | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | If you're interested in originality, I think you'll find that the 265 was discontinued and replaced by the 283 after '57. The 283 was offered in cars in '57 but not in trucks until '58.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Apr 2011 Posts: 107 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 107 | Thanks guys! Answers my questions. I think I'm going to just leave the 235 in for now and when she goes I will opt for a 283 down the line. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | "I'm kind of a original look guy and..."
You won't get an original look in a Task Force truck by replacing the 6 with an 8. Your radiator will still be in the 6 position. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | in '58 & '59 the rad position was the same for the 6 or V8 - the V8 had a shroud added to make up the difference
Bill | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | in '58 & '59 the rad position was the same for the 6 or V8 - the V8 had a shroud added to make up the difference
Bill How about a 56? i'm getting ready to put a V-8 in mine in replace of the 6. Is there a shroud for this or will I need one? George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the V8 fan will be way back from the rad so you'll either need a shroud or the original setup for 55-57 that moved the rad back and added some sheet metal pieces in front of the rad as "shrouding", seen here [and found in the assembly manual] - if you look at your inner fenders, there's a reinforcing plate with 3 holes in a triangle, that's where the core support moves to .... this is a 56 panel w/ 350 and aftermarket plastic shroud ..... and this is a 58 with a correct style shroud, but from a 60's car, slightly modified to fit because the car rad is slightly different dimensions - it'd work on the 56 as well if you can find one Bill | | |
