0 members (), 153 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
#834164 03/11/2012 4:12 AM
1 Offline
I think my manual hubs on my 1964 4x4 chevy 3/4ton are shot. When i turn them either way locked or unlocked the wheels will not turn when in 4x4.they are pretty worn because they are hard to read so im not sure when they are unlocked or locked. I assume when they are turned to the right they are locked?
Where should i look for to get replacement hubs and or do they make rebuild kits for them?
As a add on question my 4x4 shifter doesn't have any markers on it. When its all the way forward it means the truck is in 2wheel, half way up its in neutral, and all the way back its in 4wheel are my assumptions correct?
In the vertical position, the hub is free "F" (unlocked)...in the horizontal position, the hub is locked "L".
Hubs unlocked
Forward (1st position) - 2 Hi
2nd position - 4 Hi
3rd position - Neutral
Back (4th position) - 4 Lo
T-case shift instructions
1 Offline
cool thanks for the info
