0 members (),
89
Mod | | | Forums66 Topics128,271 Posts1,058,313 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83378 09/25/2007 3:26 AM | Joined: Sep 2004 Posts: 241 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 241 | I've been setting the carb idle at around 550RPM. I've noticed that after its warmed up and driven the idle seems to stick at around 650RPM until its turned off. When I restart it the idle is back at 550RPM or so. The choke appears to be working and not sticking.
Is this normal for these old Rochesters? I've had this problem for awhile. I'm not sure if its something in the carb that isn't working right.
Mark | | |
