1 members (1 invisible), 105 guests, and 3 robots.
Topics128,089
Posts1,056,440
Members48,443
It was cold and rainy today so I finally got around to writing up my article on changing the fuel pump. As the title suggests, I dummied my mechanical pump so it still looks stock under the hood.
Read all about it.
Looks great Cletis!! I need to do something like that. Mine had an electric pump direct.. I like the looks and design.. Hopefully you won't mine me copying.....Can you explain the oil pressure switch/setup??
Dan
I put a tee at the oil pressure gauge outlet of the engine and put a pressure switch in one of the holes. The switch is normally open but with oil pressure the switch closes providing power to the fuel pump.
I told the NAPA guy what I wanted and he got out the book and we found a suitable switch. I think mine is 7 psi.
Nicely done.
Nice write up, and what a great idea!
Jeremy
1950 Chevy 3800 1-Ton Long Bed
More pix on Flickr
Sold all the bikes, leaving California behind.
mo Offline
i like it also. really like the switch also always nice to have a safety system in place.
MO's 1951 chevy 3100 resto mod project
Thank you Cletis for taking the time to do the write up. I was wondering how to do the same thing on my 55 truck. And thanks to you I don't have to wonder anymore. One question, where did you pick the fuel pump up at?
I found it in an Ebay search. It was recommended to me and I searched the PN.
okay sounds good i will run a search on one.
