| | | Forums66 Topics128,090 Posts1,056,384 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83361 09/24/2007 7:24 PM | Joined: Apr 2007 Posts: 8 Junior Member | | Junior Member Joined: Apr 2007 Posts: 8 | Did trucks have power steering in 57? Does anyone have a picture of the pump mounts? I have what should be a 50's power steering actuater valve and hydrolic cylinder, but no pump. | | |
#83362 09/24/2007 7:29 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The factory power steering option used a different generator that has a splined shaft coming out the back and a different rear plate. The pump mounts to this. Those generators do pop up at swap meets if you want to go that direction, or you might look for an early '60s car or truck that used the separate mounting and pump.
Bill Burmeister | | |
#83363 09/24/2007 8:10 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Strat Kingrey - not sure but I think I have one of those old generators. I'll take a look a ASAP. | | |
