1 members (tesa), 142 guests, and 2 robots.
Topics128,080
Posts1,055,953
Members48,430
#833278 03/08/2012 4:46 AM
I have a 1949 Chevy 3100 AD. It is all stock, but i wanted to change the Rear axle to make it go faster, just wondering what axle would fit in there and make it go a little faster, or if it would be better to get a whole new frame.
brown1998 #833285 03/08/2012 4:58 AM
Any rear axle change would also require changing the transmission and driveshaft as well, as the torque tube driveline would have to be eliminated. That said, late '70s-mid '80s GM F body (Camaro/Firebird) rearends seem to be a popular swap. Other alternatives include S10, or swapping the rearend center cection with the '55-'62 1/2 ton, which keeps the existng housing. There is also a 3.55 gearset available for the stock rear, which would also keep the stock drivetrain.
Bill Burmeister
LONGBOX55 #833413 03/08/2012 7:04 PM
How about swapping the center section with a 55-66 1/2 ton and puting in the Patrick's 3:38 gears?
Or is the a center section from the 55-66 1/2 ton that has the 3:38 gears?
That would be nice
Dennis
Where is the 3:55 Gearset for the stock rearend available at, and how much is it, and how fast will the truck go after i put that in.
brown1998 #833521 03/09/2012 1:39 AM
Patrick's has them. They're around $450 for the gearset. You should be able to run at legal highway speeds without issue.
Bill Burmeister
LONGBOX55 #833558 03/09/2012 3:41 AM
Would a 1968 Pontiac Firebird Rearend fit in the 1949 Chevy 3100, just wondering cus i know where i can find one of them very easily
brown1998 #833572 03/09/2012 4:08 AM
check this link, very helpfull for axle Swaps
http://www.quickperformance.com/Technical%20Info/sus_measure.htm
47-55 chevy truck flange to flange measurments 60-62" a good swap would be 68-72 nova (i just bought a 68 nova rearend of craigslist for $70)
other good donars include 76-80 camaro/firebird. 68-95 vette
s10, and g-body cars will work with offset wheels being that their 2" shorter then the stock rearend.
hope this helps, im no shop shark but been doing alot of research, since im doing the same for my 49 3600. good luck!!!
1949 chevy 3600
bake_em #833586 03/09/2012 4:30 AM
Would a S10 4X4 Rearend Work on the truck
brown1998 #833598 03/09/2012 5:08 AM
Many people have used a K5 Blazer rear end. It is 6 lug.
I had a link to a military surplus one for a reasonable price but can't find the link. Did any of you other guys save that link?
Cletis #833653 03/09/2012 2:12 PM
Military surplus link.
Wish they had them with a 3.42 or so ratio.
Steve
'49 3800
'52 3600
'57 3100
Ghostrider #833733 03/09/2012 7:20 PM
That's the one, Steve. Thanks.
Ghostrider #833866 03/10/2012 4:28 AM
I found a 1972 Nova rearend for it, is it easy for a person to put it under the truck, i do have a welder
