4 members (KEVINSKI, DadsFirstPickup, Hanks custodian, Ponchogl), 198 guests, and 1 robot.
Topics128,108
Posts1,056,230
Members48,436
Junior Member
Junior Member
Can anyone point me to where I can find a dipstick and tube that will work on the 235/261. Mine went missing at the shop. Also who makes an adapter for the factory oil filter on a 62 261 that lets you use a spin on filter? Thanks
i'm not sure about a 235 but for 250/ 292's i have used brake line to make a tube. i don't remember the actual size but i bought it where the od is slightly oversized and cut it down to a shoulder about a inch down on my lathe. then drove it in. you can even use the original mark on the dip stick if you made the tube long enough and put it in and measure down to freshly filled crankcase. then cut off with a tubing cutter or you can rescore the stick. can rebend tubing to close to original bends aswell. i'm sure they turn up on ebay from time to time. hr
I did the brake line trick too, 5/16" line works best. No step down needed on the 235, though. length is about 8 3/4". As for a spin on filter, any of the remote style filters will work, Trans Dapt has a good selection.
Bill Burmeister
