4 members (TexasJim50, 3B, Otto Skorzeny, 1 invisible), 66 guests, and 8 robots.
Topics128,013
Posts1,055,322
Members48,419
#833347 03/08/2012 1:49 PM
Is there a quick way to wire in the ignition system with no other connections made to anything else? Just want to help a buddy start a truck to check the engine. I guess it's like "hot wiring". wink
I should add that this is a 1959 261 engine.
Drew
Hook the starter supply to the positive of the coil. Actually if the horn has pawer, you can tap off there. For starting the first time, I like to power the coil separately from a battery charger. That way you get the best possible spark even when the starter is drawing a load.
1951 1 Ton Completed
OK. Thanks.
Drew
