| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Is there a quick way to wire in the ignition system with no other connections made to anything else? Just want to help a buddy start a truck to check the engine. I guess it's like "hot wiring".  I should add that this is a 1959 261 engine.
Drew
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Hook the starter supply to the positive of the coil. Actually if the horn has pawer, you can tap off there. For starting the first time, I like to power the coil separately from a battery charger. That way you get the best possible spark even when the starter is drawing a load. | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 |
Drew
