3 members (gswbbc, Rusty Shackleford, Gdads51), 102 guests, and 3 robots.
Topics128,047
Posts1,055,532
Members48,424
#83301 09/22/2007 11:37 PM
V
V Offline
I have a 1985 linclon rear end. I believe the it is a 3.08 with disk breaks. I did not have any luck trying to find any information on the width of this. Will this work in 1/2 ton or am i going to pull my hair ot trying to install it ?
#83302 09/23/2007 2:04 AM
If you have it, measure it.
You don't say what year 1/2-ton you have. The rear under my '55 1st 1/2-ton is 62 inches wide across the wheel mounting surfaces, which unless you are running a real deep wheel is about right on an AD truck.
#83303 09/23/2007 4:54 AM
if its out of the 2 door, the ones with the factory air bags they are 62 inches i put one in my 49 suburban and it fits great i had 16x6 multi lug steel wheels made. i installed it on my stock leaf spring because i did not want to move my gas tank. i seen guys install them with the lincoln factory 4 link
1949 SUBURBAN
