1 members (moparguy), 98 guests, and 2 robots.
Topics128,129
Posts1,056,360
Members48,441
#832493 03/05/2012 8:57 PM
Did you guys see the twin screw Spartan on ebay? Its in the chevrolet pick-up section.
Still looking for a 10500.
I saw that...it's a 10713 with the 192" wheel base. I sure hope it finds a good home.
Here's the link.
Mike B
http://cgi.ebay.com/ebaymotors/?cmd=ViewItem&_trksid=p3984.m1438.l2649&item=330694474384&sspagename=STRK%3AMEWAX%3AIT
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
LCF,
What year 10500 are you looking for?
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Its got a lot of seldom seen components such as the 348 engine, auxiliary transmission, straight air and the early style Eaton 3 speed rear end that was only used for a few years.
Crenwelge,
You are right, this is a rare truck.
It has the Power Divider Aux Transmission and Corporate GM Single Speed 15K Rears. The power divider is 3-speed (low-low, low and direct), it also has the ability to disengage the rear rear.
Also, the 348 was the only motor available in the 1958/59 Sereies 90 and 100 trucks.
Someone is going to have a neat old truck!
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
I wonder if that rear wasn't a Chev only thing meant for vocational use such as a mixer. GMC only used the corporate rear up to the 370 model. The 400 and larger used either a Rockwell or Eaton. Eaton had a similar looking contraption, but went to a through shaft like Rockwell. I have GMC books from 1955 through the early 60's from the 100 series up to the 970 series, and I don't see anything like this Chev has.
Mike B,
It really does not matter 56 or 57. I want to use it as a tractor to pull an 48 ft enclosed car trailer. Thanks for the reply.
Geary
