1 members (Hotrod Lincoln), 49 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#832083 03/04/2012 3:36 PM
Hope someone has had this issue before. I spent this winter going thru a 350 chevy engine finally got in done and instaled in my 1958 60 series truck. fired it up yesterday ran like a top. The problem is the clutch acts like it is not disengaging. But when I crawl under the truck and someone pushes the clutch pedal in I can see the clutch open up, If I start the truck in gear it will take off even if the clutch is pushed in all the way. Does anyone know what I did wrong.
windmillguy #832106 03/04/2012 4:46 PM
3B Offline
Hy windmillguy, it sounds like the clutch disc may be stuck to the flywheel. If you have something big and solid around, a tree, a wall, a building, you could back the truck right up against that object, and with the clutch depressed start the truck, or at least try to start the truck, this may break the clutch disc free. You can also try sliding a thin putty knife between the flywheel and the clutch disc, while someone is holding the clutch pedal down, hope that helps.
3B #832172 03/04/2012 9:31 PM
Riding in the Passing Lane
Could you have got the disc in backwards?
1972 Chevy c10 Cheyenne Super
Wrenchbender Ret. #832368 03/05/2012 1:54 PM
Thanks for the advice I will try putty knife first. Another thing I forgot to mention was it won't move if I start it in high gear. Does that mean anything? Knowing me I very could have gotten any and everything backwards. thanks
windmillguy #832380 03/05/2012 2:49 PM
Sure sounds like the clutch plate is in backwards.
I have done that.
Stevenichol #832645 03/06/2012 4:13 AM
Tried putty knife. started pulling engine again more than likely clutch plate, at least weather man is only calling for wind and no snow so it won't be to bad appreciate time and advice
