| | | Forums66 Topics128,105 Posts1,056,538 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83250 09/22/2007 4:27 PM | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | I want to replace the valve seals on a 216 motor. I have a valve spring tool and it compresses the springs but the keeper at the top won't come out. I've tried this on several springs and none of them will come out. What am I missing or doing wrong? Also, what's the consensus on the type of seals to use, umbrella or O ring? I'm not doing a rebuild at this time, just replacing some leaking seals and gaskets. | | |
#83251 09/22/2007 4:45 PM | Joined: Feb 2004 Posts: 29,835 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,835 | Squirt a little penetrating oil on the retainer/keeper assembly and give the retainer a medium-firm tap with a ballpeen hammer before compressing the spring. Is the head on or off the engine? If you're doing the seal change with the head on, be sure the piston is at TDC or close to it to avoid dropping the valve into the cylinder. Once the retainer is compressed, use an awl or an ice pick to pry the keepers out of the groove. Sometimes they stick pretty tight.
If there's any noticeable wobble of the valve in the guide from wear, an umbrella seal will get you a few more miles before it's time to replace the guides. If the guide is snug, use the original O ring seal. Too much sealing will cause guide wear due to lack of lubrication. Jerry
#83252 09/22/2007 4:48 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jim,
It sounds like the tool isn't compressing the spring adequately. Isn't the compressor adjustable. If it isn't, can't you put a thin wood shim between the valve and the compressor finger, on the combustion chamber side to take up some room and allow for full compression of the spring.
Weren't the little stem seals the factory item? I remember putting umbrella seals on for added measure, but the stock stem seals worked fine if the guides weren't totally worn out.
If your spring compressor is adjustable, as it should be, you should be able to compress the valve spring until it is bound.
Stuart | | |
#83253 09/22/2007 5:10 PM | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | The head is still on the engine. I know all about valves dropping inside the cylinder if not at TDC. I did it only once. The tool is adjustable and will completely compress the spring. I've used this tool before to replace seals on a small block chevy. I'm sure the valve guides are worn. | | |
#83254 09/22/2007 5:15 PM | Joined: Feb 2004 Posts: 29,835 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,835 | Once the spring is compressed, tap the retainer with a small hammer. Years of pounding get the parts stuck together pretty firmly. Just don't bend the valve in the process. Jerry
#83255 09/22/2007 5:49 PM | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | The spring compressor I'm using looks like a small gear puller. There is no room to tap the retainer with even the smallest hammer. The clips are so tight that the spings pull up from the bottom instead of being pushed down from the top. | | |
#83256 09/22/2007 7:32 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jim,
I have used a hammer and deep socket that fits onto the retainer to break the hold between keepers and retainer.
If you give the socket a good smack while holding it at a very slight angle, the retainer will tip and release its bond with the keepers. You might have to do this a few times, then try your spring compressor.
All this monkey motion is done with the rocker assembly removed.
Stuart | | |
#83257 09/22/2007 8:10 PM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Stuart is right about the way to loosen them. On an engine where the valve can hit the piston when wacked it is better to use the air fitting in the spark plug hole to keep the valve closed. with the rockers off the air pressure will push the piston to the bottom and out of harms way. In the 60's we did all the warranty work for Olds and Ford in the Dallas-Ft Worth region which amounted to around 105 SETS of heads a day. 90% of the retainers and keepers were removed by the big brass hammer and deep socket method; didn't have time to use even our air powered spring compressors. You cannot do this with the block surface of the head on the bench or it will bend valves when they strike the bench. Same with a piston on TDC on some engines.
Evan
#83258 09/22/2007 8:54 PM | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | Evan and Stuart,
I have the compressor and fittings to do this. Do you think I should also get a new set of keepers? | | |
#83259 09/22/2007 9:14 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Jim,
Although the fit between keepers and retainer isn't a moving fit, my feeling would be keep the old with the old...if you replace the keepers, replace the retainers.
I personally would stick the old stuff back on, it pretty bullet proof.
Stuart | | |
#83260 09/22/2007 9:27 PM | Joined: Jan 2007 Posts: 81 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 81 | I used a spring compressor loaned me by autozone. It worked well except the narrow bottom spacing of the variable rate springs caused a bit or a problem. This compressor pressed down on the valve retainer and loosened the keepers. I happened to have a small rod mounted magnet made to fish dropped nuts out of inaccessible places. It worked wonderfully for fishing the keepers out of the retainer. Also worked well for dropping them back in place after installing the umbrell seals. The compressor I used would not allow me to do the back (exhaust ) valve which is somewhat recessed under the firewall. There is an argument made for not even installing umbrella seals on the exhaust valves. I'm told that the original factory valve seals (the o rings) only serve to prevent drain down of oil collected in the retainer cup when the engine is stopped. That collected oil would otherwise trickle down through the keepers and down the stems into the combustion area to produce smoke for a minute upon startup. meansam | | |
