| | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 35 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 35 | Is the round trunnion for the tailgate hinge supposed to stay in a fixed position or is it supposed to rotate freely when the tailgate is opened and closed? If it is to stay in a fixed position, should it be greased-up so that the tailgate rotates more easily around the trunnion?
Thanks, Steve
| | | | | Joined: May 2010 Posts: 303 Shop Shark | | Shop Shark Joined: May 2010 Posts: 303 | the truninons on my 55 2nd series just slide in. There is a slot recessed into the trunion. And there is a hole on the bottom side of the tail gate where you can slide a flat head screw driver in to hold the trunion in place while you tighten the bolt. The trucnion will turn freely when you open and close the tail gate. I put a little dab of bearing grease on mine before I installed them. | | |
