5 members (porsche, Bill Hanlon, Steelonsteel, ‘37ChevyPU, carbking), 99 guests, and 1 robot.
Topics128,051
Posts1,055,767
#832219 03/05/2012 12:59 AM
I was looking at the oil pump pick up on my 261 to day and at the bottom center there is a very neat 3/8" dia. hole in the screen. Now I'm thinking why have the screen with a 3/8" hole in it or is the hole isolated from the screen area? Maybe there was a plug there that fell out? I looked at the online manual but couldn't find a close up picture of this detail, Can someone help me out with this ?
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4
1967 Jeep Cj5 with 283 SBC
sleeve #832308 03/05/2012 5:11 AM
Hole = bad
panic #832388 03/05/2012 3:16 PM
Thanks Panic, It looks like I have some replacing or fixing to do.
Any one have an oil pump pick assembly for sale ???
sleeve #832579 03/06/2012 2:17 AM
An update on this: Taking a closer look today I found that due to metal fatigue some of the sheet metal at the bottom side of the sump pick up had fallen away exposing the 3/8'' grommet hole in the screen that the metal originally covered..........I've never seen anything like that before!
sleeve #832854 03/06/2012 11:44 PM
If it looks like THIS it is a by-pass hole. It is designed to let oil into the oil pump if the screen gets plugged. If the screen gets plugged the screen is sucked up away from the cover exposing the hole.
It should not normally be exposed.
My Blog
