4 members (klhansen, jay d, jmoore, 1 invisible),
129
Mod | | | Forums66 Topics128,288 Posts1,058,577 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 4 New Guy | | New Guy Joined: Feb 2012 Posts: 4 | My 58-62 235 has 150 lbs of compression on cylinder #1, 130 on #2, 130 on #3, 90 on #4 and leaked down quick, 140 on #5 and 120 on #6. It smokes like a freight train I assume because #4 cylinder spark plug was fouled with oil. All others looked good. # 1 was a little sooty but the rest were fine. The car had sit for several years and the gas was really bad.
I have a 261 that I can replace it with but would like to save the 235 just to put around in while I build the 261.
Could the valves and/or guides be the problem?
| | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | could also be that the rings are a little frozen up or worn.
Kurt | | | | | Joined: Feb 2012 Posts: 4 New Guy | | New Guy Joined: Feb 2012 Posts: 4 | Maybe some Marvels Mystery oil in #4 might unstick a ring? | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | Worth a shot for sure. Don't run it too hard.
Kurt | | | | | Joined: Feb 2012 Posts: 4 New Guy | | New Guy Joined: Feb 2012 Posts: 4 | Found the culprit, the number 4 cylinder push rod was bent. I seem to remember my old 52 chevy having the same problem 45 years ago. When the push rod would bend the motor would smoke like a freight train. Replace the bent push rod and the smoke went away. Put in a new push rod, adjusted the valves and it purrs like a kitten after sitting in a shop for 12 years. The carburetor needs rebuilt as it won't run without feeding gas by hand. Haven't checked the fuel pump pressure yet and it may also be bad but I am encouraged with the outcome so far. Keeping my fingers crossed.... | | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | Hey Snowball -- for us non- mechanic types -- how did you know the push rod was bent? Was it obvious, as in not straight, or was it something you just tried and had success. I have one tapping, not sure which, and lots of smoke. Not to hijack your thread, just wanted to know what you saw, heard, or how you determined it was bent.
Dale | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Hey Dale; It might be as simple to find as pulling the valve cover and watching the pushrods as in this VIDEO Good luck. | | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | Thanks Waldo! - the video really helped -- it was very clear that pushrod is bent! Now I know what I might be looking for. This has been a good thread.
Dale | | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | I am at a loss to figure out how a bent pushrod makes it smoke. How does that cause it to smoke? | | | | | Joined: Sep 2011 Posts: 1,468 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,468 | I am at a loss to figure out how a bent pushrod makes it smoke. How does that cause it to smoke? If was an intake pushrod non-opening intake valve would result in vacuum in cylinder when exhaust opens pulling oil past exhaust valve guide directly out into exhaust manifold.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | Oh, that is something. So the burning is taking place in the exhaust itself. Thanks for the explanation. | | | | | Joined: Feb 2012 Posts: 4 New Guy | | New Guy Joined: Feb 2012 Posts: 4 | The video shows a push rod that is really bent. I found mine by twirling the rods under tappet and you can easily see one that is even slightly bent.
After rebuilding the carb and replacing the fuel pump, intake/exhaust manifold gaskets, push rod and plugs it started right up and purrs like a kitten. I took it for a spin around the block and it was a blast. The brakes, steering and suspension need some work but not much. I can't wait to get it out on the road. | | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | They are much more interesting to drive than today's vehicles. | | |
