| | | Forums66 Topics128,086 Posts1,056,094 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83208 09/20/2007 9:20 PM | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Ok someone out there should be able to tell me this, what is the width of a dually normally. What is the width without the two extra wheels.
I need to get it past my house and that is pretty tight to fit back there, I have fit a full size in the back before but I am concerned about the duals.
Thanks | | |
#83209 09/21/2007 2:29 AM | Joined: Apr 2005 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 42 | I can't tell you specifically about any truck but teh legal width limit on city streets is 96 inches. Teh trucks I buy at work can't run the tire size I prefer because it puts it a quarter inch too wide to be legal.  | | |
#83210 09/21/2007 2:45 AM | Joined: Mar 2006 Posts: 319 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 319 | You must not be acquainted with the Old Online Chevy Manual site maintained by Keith Hardy. Here are the resto paks. http://chevy.tocmp.com/chevyresto/index.htm Go to the year and model you are asking about and look for the info on frame and chassis data. You should find your answer there.
"Nothing astonishes men so much as common sense and plain dealing." - Ralph Waldo Emerson
#83211 09/21/2007 1:19 PM | Joined: Dec 2006 Posts: 197 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 197 | Ok so dumb question even though I can guess the answer, that site does not list a 52 truck, but it has a 53 so I assume that they are the same, correct? Thanks | | |
#83212 09/22/2007 3:25 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | The '52 and '53 are probably the same width, but unless you know the truck is all original the width listed in the restoration pack may not reflect the width of your truck.
My copy of the restoration pack for a '55 1st (should be the same) actually gives only the width across the center of the outer tires, not the outside measure. Maybe others have a different version?
I have one dually that came to me with an 80's rear under it. I've not measured to see if its the original width or not. Also changing the wheels or tires could change the width.
What model truck is this? Is it a 3800?
A stock 3800 dually should be just under 80 inches measured across the rear tires. My '54 GMC 250 (basically the same thing as a 3800) is 79-3/4 inches across the stock wheels and what I believe are stock size tires.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
