1 members (Danielbolt), 164 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,456
Converted my 1949 to 12 volt and used a 6v horn relay. Worked for a while now horn is always on unless you disconnect power to relay. Did I fry relay?
Anyone have installation instructions for town and country horns?
My restoration shop hooked both horns to top tab on relay and left middle tab empty (no connections). Was this correct?
Many thanks.
My rule of life: You can have anything you want; you just can't have everything you want.
Riding in the Passing Lane
You need to use 3 connections on the relay. They are usually marked on the bottom. One goes to bat power. One goes to the horn button & the other goes to the horn/horns.
1972 Chevy c10 Cheyenne Super
I used a 12v horn relay from my local auto parts store
It came with this sheet
...<click>...
wired it like this
...<click>...
