0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Will a fresh air heater from a '53 work in a '54? Thanks.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes it will. Hope you got the cable with it. | | | | | | OLTrucks Unregistered | | OLTrucks Unregistered | Yes, same heater, The "Air Flow" heaters came out in 1953 and was the same (except the control knob)till 1955 1st Mike | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Thanks for the info. If you're meaning the defroster cable. no, I didn't get that with it. There's a wrecking yard around here that has several AD trucks in it. I might get lucky nd find one there. I did once before.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | On a 53-55 Advance-Design truck outside-air "De Luxe" heater (AirFlow, Fresh-Air), there is no defroster cable (as was used on the earlier style, similar "De Luxe" heater).
The cable in 53-55 is used to open and close an interior-air/exterior-air door on the right-front face of the heater (to regulate between blowing/heating all outside-air to all inside-air).
The 53-55 defroster-lever is hand-controlled (or, maybe, foot-controlled) using the lever on the left front of the heater unit (as used on the recirculating heater).
