2 members (51sub, Possum),
113
Mod | | | Forums66 Topics128,265 Posts1,058,364 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83133 09/19/2007 2:04 AM | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | I have a '61 Biscayne 235 mounted in my '53 pickup. The distributor number is the same for both the '61 car block and the old '55 truck block. The new distributor I ordered has a different number, but all matches up. The new one didn't come with the vacuum advance. My '61 distributor vacuum advance is angled at 45 degrees. The old one that came out of the '55 distributor is a straight mount. Both will line up and work on the '61 block. I fabricated the vacuum line to run parallel to the block and the advance that came out of the '55 would allow for a connection to the vacuum line straight on. If I use the advance from the '61 distributor, I'll need to re-do the vacuum line I just made in order to make the screw-in connection. So my question is, is there any reason I can't use the straight-on advance as opposed to the 45 degree advance? Are they interchangable? | | |
#83134 09/19/2007 2:36 AM | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Use whichever vacuum advance unit that better suits your plumbing. | | |
