4 members (Stovebolt48, Steelonsteel, Bill Hanlon, lumbersawyer), 31 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,422
#831116 03/01/2012 1:59 AM
Saw something I had never seen before today. I tried to start my 52 and no luck, think I need gas. But to the thing I saw, don't know what possesed me but I looked under the hood to see if accelerator pump was working, I grabbed hold of the fan and tried to turn it. When I took the pressure off of the generator it srarted spinning to beat the band. What happened was I didn't turn the key off but took the key out, my ignition is that way. As soon as key was off no gen spin. Is this normal???
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Your 'generator' had convinced itself it was a 'motor'... Power from the battery was probably shorting through it. Check your wiring and re-polarize the generator.
Two problems: The fan belt is way too loose, and the cutout relay is sticking, allowing the battery to discharge itself through the generator. Eventually, the relay will stick, the genny won't turn, and the wire harness will burn up. I'd strongly suggest looking into the situation and getting it fixed!
I feel real fortunate that I caoght it, I could have burned the whole place up, I would have really been mad.
1941 Chevy
