0 members (), 50 guests, and 3 robots.
Topics128,211
Posts1,057,475
Members48,473
Does the primary (long Pad)go on the side facing the front of the truck or to the rear of truck and is the same for rear wheels also?
3B Offline
Hy Focus, the shoe with the short lining is the primary [front] shoe, it is installed on the forward [front] side no matter which wheel position you are working on, hope that helps.
3B
I thought that was the way but it always helps to have it confirmed.
I was confused because the back ones that I removed had the emergency lever attached to the small liner and it was mounted to the rear of wheel.That might be part of the problem I am having with the emergency spreader bar also Hmmm!
