| | | Forums66 Topics128,212 Posts1,057,468 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83104 09/18/2007 8:31 PM | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | Does the primary (long Pad)go on the side facing the front of the truck or to the rear of truck and is the same for rear wheels also? Thanks | | |
#83105 09/18/2007 8:55 PM | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy Focus, the shoe with the short lining is the primary [front] shoe, it is installed on the forward [front] side no matter which wheel position you are working on, hope that helps. | | |
#83106 09/19/2007 7:29 PM | Joined: Jun 2007 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 68 | 3B Thanks, I thought that was the way but it always helps to have it confirmed. I was confused because the back ones that I removed had the emergency lever attached to the small liner and it was mounted to the rear of wheel.That might be part of the problem I am having with the emergency spreader bar also Hmmm! Thanks | | |
