6 members (greenie-reddy, GMCJammer51, 2-Ton, 3B, 55shaker, JW51), 94 guests, and 0 robots.
Topics128,154
Posts1,056,834
Members48,456
The fuel gauge on my '52 panel always reads 1/4 full when the ignition is on, whether the tank is full or empty. Turn the key off and the needle drops to "E". The ground, etc. appear to be okay, everything checks out as per Shop Manual. Maybe the resistor to drop the 12 volts to 6 is gone? Any clues?
3B Online: Content
3 Online: Content
Hy chevypanel52, it could be the sender in the fuel tank, if you can remove the wire at the sender and ground it temporarily you should see gauge movement with the ignition on, if the gauge goes to full then it would appear the sending unit is not functioning correctly, hope that helps.
Ex Hall Monitor
Ex Hall Monitor
I suspect the float rod on the sending unit is stuck in place but you won't know that for sure until/unless you pull the sending unit.
Sounds like I have to pull the tank ... a job that will have to wait til the truck's up on a hoist this spring for brake adjustment, oil change, etc.
