8 members (KEVINSKI, Charles in CA, Otto Skorzeny, 1955 1 Series, Hotrod Lincoln, ShopRag, Gray_Ghost, Peggy M), 188 guests, and 3 robots.
Topics128,267
Posts1,058,373
Members48,485
#830944 02/29/2012 4:44 PM
Hi everyone,
Just purchased a 1950 3100 with original 216. Have not had a chance to identify existing single barrel.
Truck drives well but there is a whistle coming from carburator upon acceleration.
Could this be a vacuum leak, throttle shaft leak?
Thanks for any replies.
Kurt
Yes, it could be a vacuum leak and the throttle shaft is a possible culprit. Try wiggling the throttle shaft by hand to see if there's any play at all. The Rochester I had on a 216 manifold (235 engine) had that problem causing, I assume, a bad flat spot on acceleration. I switched to a Carter on the correct 235 manifold and it now runs great.
BTW, welcome to the board Kurt!
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
