7 members (Bill Hanlon, tclederman, KEVINSKI, Sjm, Oswald, 2 invisible), 162 guests, and 2 robots.
Topics128,260
Posts1,058,288
Members48,485
#83079 09/18/2007 4:19 AM
I have been driving My 59 for about two summers with my new A/C unit installed. It has been doing great however, this past Sunday I drove her about 2 miles to the Wall-Mart and she started spilling the coolant, when I turned off the motor. I didn't realize the guage was hot.
.. I went ahead and bought some more coolant there at the store, drove her home and checked the oil, belts and radiator... everything was good.
Tonight I drove the bolt to work with the A/C on, and again she got hot. I turned off the A/C, and drove for several more miles. Even at a stop light she was ok, no overheating. As long as the A/C unit was off she ran cool. It is still 90+ degrees here in Texas, nothing has changed from this summer...
Is there any thing else I should look for?
What am I forgetting?
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
#83080 09/18/2007 4:34 AM
Check and make sure your thermostat is opening. You shouldn't run a high % of coolant (antifreeze) in that hot weather...you might want to consider an 80%water /20% coolant mix...more water..better cooling.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
#83081 09/18/2007 4:41 AM
I think the thermostat is ok... but I will check it out (or change it out) this week.
I have been running 50/50 but I will go ahead and make it an 80/20 mix.
#83082 09/18/2007 4:57 AM
CLIFF59,
My thought would be to take a peek into the radiator...it is the variable in this situation.
Is it possible that it is becoming plugged and is just over the threshold of being able to cool your truck with the added load of the AC compressor on the engine.
Stuart
#83083 09/18/2007 10:58 AM
Huuuummmmmmm...... ???????
I have checked the Radiator before but not in about 6 months... I have never noticed plaque
or anything out of the ordinary.
I will take a closer look this week.
Thanks Stuart
Cliff59
#83084 09/18/2007 2:08 PM
I was having some of the same problems with my ride. Running a 50/50 mix with new alum. radiator with A/C on. Pull off the interstate into heavy traffic in August and the heat would build. The people who built my radiator said the thing is good for a lot more ponies than my L6 is making. I noticed my aftermarket radiator cap was getting corrosion on it. Got a "water-wetter" as it has anti-corrosive stuff in it. The antifreeze mix is 25/75 with a quart of this "water-wetter" in it. The heating problem has gone away. No more than a 5 deg. swing in any traffic condition. Don't know what fixed it...the ratio mix or the "water-wetter".
#83085 09/18/2007 2:25 PM
I go about 70/30 alla time here, it just don't get that cold to need 50/50.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#83086 09/18/2007 2:31 PM
Ethylene Glycol is denser than water and will therefore carry more heat away from the engine. The boiling point of Ethylene Glycol is up around 275°F vs 212°F for water. The reason that 50/50 mixture is commonly recommended is because it is a good all round mix that gives better heat conduction than plain water and covers most of the low temperature conditions that we run into in the States. Most Ethylene Glycol manufactures call out a maximum 70% mixture should you be exposed to extreme cold which will give you protection down to –75°F or –80° F. Of course these numbers will vary depending on the pressure the system is under.
If you didn’t have cooling problems in the past then it is only logical to assume that you are having a problem with the stat, the cap or with a blockage somewhere in the cooling system.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#83087 09/18/2007 2:43 PM
This may sound like a silly question, but have you cleaned all of the bugs out of your A/C condensor and/or your radiator. I had the same symptoms you are describing with my 1991 Chevy truck when I lived in Stephenville, TX. It seems like the spring and early fall are bad times for bugs building up and blocking the airflow through your radiator. Since this has been a wet year, the bugs are probably worse.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
#83088 09/18/2007 2:56 PM
knuckle head
knuckle head
Denny,plain water is a better coolant than Glycol,but water obiviously doesn't have frreze or corrosion protection.
#83089 09/18/2007 4:37 PM
Q
Apprentice
Apprentice
Q Offline
I been all through this , Fast truck has it right . Water is best at transfeering heat . The water wetter is supposed to help but have heard it were it did nothng , yea I poured a bottle in my drag car .Anti freeze is just that and a anti corrosion agent .
On my nova i have gone to a electric fan, A few extra HP from not having that fan to spin and better cooling . I use a 2 spd fan from a ford Taurus , pulls a suprising 3200cfm
#83090 09/18/2007 5:55 PM
As a point of fact, pure water transfers heat about 50% better than anti-freeze or a substantial anti-freeze mix. However, as previously noted anti-freeze does raise the boiling point and is a corrosion inhibitor. So a mix based on your temperature situation is indicated.
Steve G.
#83091 09/18/2007 6:14 PM
Also, make sure timing is up to specks, and the vacuum advance is working properly. If it still has points, double check the dwell.
If the timing gets a little slow, it will cause heating problems.
#83092 09/20/2007 5:50 AM
Just read this paper and I stand corrected. http://crownsolutions.com/pdfs/Glycol.pdf I have been operating for more years than I care to admit under the false assumption that the denser fluids would transfer the heat best. Learning something new every day is what keeps life interesting.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#83093 09/20/2007 11:11 AM
changed the thermostat and the oil.
had the radiator checked and..............
the Radiator is A-OK
the oil was getting thick and bad.
the thermostat looked ok but (what the hay)?
now the bolt is running cool! cool and happy,
even with the A/C running and at a stop light! smile
thanks guys
Cliff59
#83094 09/20/2007 11:15 AM
Quote
Denny Graham
Sandwich, IL
good to know info!
cliff59
