5 members (Otto Skorzeny, Joe H, Uncles51, Gdads51, 1 invisible), 117 guests, and 5 robots.
Topics128,075
Posts1,056,003
Members48,433
#830480 02/28/2012 4:21 AM
HiGuys I have a 69 c 50 292 and have new everything plugs wires cap rotor rebuilt carb. checked everyting and it is still back firing thru the carb. at around 40 miles. rebuild the distubrator? I ask if maybe needed new timing chain but shop did not think so. engine has 93.000 miles. Any ideas Thanks Tony
3B Offline
Hy crockbuyer, have you done a compression check? If you have and everything was good, then you might have a sticking intake valve, or possibly a broken intake valve spring, hope that helps.
3B #830561 02/28/2012 2:00 PM
Are you sure you have the plug wires hooked up right? Easy to get switched around....
Kurt
