9 members (Nick in Manitou, Gray_Ghost, Shade Baby, J Lucas, TUTS 59, Bill Hanlon, papas52, 2 invisible),
120
Mod | | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Maybe the phrase "If all else fails, get a bigger hammer" works on most occasions but today I spent too many hours trying to remove the two king pins from the axle beam I'm current restoring. The top soft caps came off pretty easy and YES I did remove the wedge bolt thingy that stops the yokes from turning too far. I'm about to hire a auto machine shop to remove them if I can't go much further. Any ideas? I heard that a torch helps but I only have those small butane torchy things, nothing industrial.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Oct 2003 Posts: 70 Member | | Member Joined: Oct 2003 Posts: 70 | | | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Sounds like your having fun!! I went thru the same problem, and decided to have a heavy duty truck spring and axle shop take care of mine. Well worth it!! I gave them my axle and I also had them install the new king pins and shim them properly and then I re-installed everything. I read here that if the axle is still in the truck you could lift the truck up using a pipe and raise the truck by placing the pipe under the king pin and the weight of the truck would drive it out, but it sounds like you already have the axle out, and so did I at the time.
Heavy duty truck shops who do spring and axle work do these king pin jobs all of the time. When I went in there he already had like 6 or 7 larger versions of what we have on our trucks in process. It kinda made me feel good to see that going on. Good luck and show us some pics if you can!!
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | TrknGMC, Loads of fun and then some. Your suggestion of truck shop might be the way for me to do, but I'm going to first sand blast my parts and por-15 them before I have the shop assemble. Yep, my axle is out in my wood shop. It's an extra axle assembly ('53) that I'm putting into my truck so I can have Bendix all around.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If your axle is not mounted in the truck, there is no need to struggle with trying to remove the kingpins. A shop can use a big press and just enough force to move them out.
I removed mine with the assembly still together but no fenders to get in the way! I used a full size sledge hammer, a screw jack under the axle and a wrist pin as a drift. The driver's side was the toughest to remove. The other day I was cleaning up the floor and I discovered that I had left the imprint of the jack base, in the concrete! Now I know why it took so much of my energy. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I have done a couple of sets of king pins recently and I use a 20 ton press from Harbor Frieght. At one point, I had the press maxed out and the acetylene torch warming the area when it decided to "pop" loose. The press and all the hammers and tools laying on it jumped a couple of inches off the ground and I about had to go and change my drawers. Sometimes it is amazing what it takes to get these old king pins out. The other side came out really smooth and easy. Go figure. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I'm going to contact a couple truck shops tomorrow. I have tons of other stuff to do instead of banging my brains out and ruining lots of tools, just to remove these stubborn pins. Once removed everything gets sand blasted, Por-15'd and then reassembled.
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Most guys say, gee it is almost worth it to take it out and to a shop. Yours is already out. It will be cheap and do no damage to the parts. I bet you are chewing stuff up a bit this way.
54 3100 with 235 62 flatbed dump C60 with 261
#8300 10/26/2003 11:50 PM | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | cmayna: It takes lots and lots of heat and patence, and ONE big sledge. Took me 40 min. for 1st one after I learned it took 10min for 2nd. I am pretty good size myself. By all means if you dont have good torch take it to shop, that's got to be the easiest. popcorn The Truth is Out There (good luck keep us posted) | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Tomorrow I'll be calling around for a good shop. Meanwhile I ground off the peening from both steering arm balls so the shop can remove them as well.
| | | | | Joined: Jul 2003 Posts: 26 Apprentice | | Apprentice Joined: Jul 2003 Posts: 26 | Hey guys I am about to do the same for a chevy '51. Do anyone of you have a picture of the arrengement (Jack and wrist or the like) to hammer those pins out?. Sometimes I am as stouborn as those pins. I will give a try.
Chevy'51 GMC '54 GMC '56 GMC '59
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Took my axle and steering arms to a local diesel mechanic who snickered when he saw what I had saying "gees, the kingpins I replace are heavier than your entire axle." All I could do is smile and ask when he could get to it. "Done by tomorrow".......
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | We have a local truck shop that does frame, axle & spring work. They also do a lot of classic pickups. I took my 52 3/4 ton in, had new kingpins installed and front end aligned. And my back didn't hurt when I was through!
Fred 52 3600 69 C-10
| | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Cmayna: That is about the same response I got from the spring/truck guy in my town!! Funny isn't? I paid $150 total, and that was to remove old king pins from axle, ream/machine axle to fit oversize king pins, and to repair both spindles, both sides had worn down and then he put the whole unit back together with new grease fittings and greased it for me. Let us know what this guy charges you, just for reference.
Sounds like alot of FUN!!!
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | mine was easy - beat on it for an hour with a pin setup and a 16 lb sledge - nothing. Then remove axle take to shop - 60,0000 press - nothing. Then heat whole schmear with a torch until cherry red - finally the pins came out. Turns out when they reamed the pins last time, the rotated one of the bushings - no grease nowhere. :mad: Oh well, fixed now. | | | | | Joined: Sep 2003 Posts: 55 Member | | Member Joined: Sep 2003 Posts: 55 | I got the first one out in 4 hours and the second one in 4 days. I'll never do it again. I'm going to the shop next time. LOTS of heat and pound away. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Picked up my front axle tonight and steering arms tonight. He charged me $50 to remove both king pins, brash bushings & the balls from both steering arms. I told him that I was going to have my axle & yokes sand blasted, then I would Por-15 them. Afterwards I'll bring the set back to him so he can install the new bushings and pins. He looked at my truck and just smiled "If only modern trucks were this simple".
This ole geezer lives where he works, has a cat that to him is the queen. Since I love cats, I easily bonded with him and there we went.....
| | | | | Joined: Nov 2001 Posts: 182 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 182 | Craig, what are you going to do with the axle you're replacing? I know you're busy...email me when you can. | | |
