| | | Forums66 Topics128,007 Posts1,055,278 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#83042 09/17/2007 2:10 AM | Joined: Aug 2007 Posts: 17 Apprentice | | Apprentice Joined: Aug 2007 Posts: 17 | I currently have a 327/T400 in my 52 p/u. I'm considering swapping the 327 for a Caddy 512; anybody out there thats done that before? Any tips? Appreciate your inputs.
PBO | | |
#83043 09/17/2007 2:55 AM | Joined: Mar 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 63 | I am looking on putting a 283/TH350 in my '52. Did you have to move the steering box over. Anything else I need to be aware of for this conversion. Also, I know of a guy here in Klamath Falls, OR looking for a 327 if decide to put in the 512. Have fun with your project, Wayne | | |
#83044 09/18/2007 12:36 AM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Here is a shot of a 500 caddy in a 51 GMC which is the same as your Chevy. Been in it for over 30 years and 200,000+ miles(rebuilt twice). Go to page 2 and scroll down to blue truck. http://s32.photobucket.com/albums/d41/coilover/ To ZB3--don't have to move box if you use a 55 or 56 265 exhaust manifold.
Evan
#83045 09/18/2007 12:49 AM | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Hey coilover, Would you tell us about that steering conversion? Looks interesting. Thanks, Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
#83046 09/18/2007 2:26 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | FYI: a '51 GMC is not the same as a Chevy. The crossmembers are different. There's less space between the radiator and the firewall on the Chevy. | | |
#83047 09/18/2007 3:47 AM | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Weird looking steering job there. I've seen something like that before but can't remember where or what it was.
~Jim
#83048 09/22/2007 7:14 AM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | When your doing something like a 500 Cad into an AD truck the original radiator position doesn't mean squat and, the front sheet metal clips will swap if you fab a new core support so they're the same truck from a swappers point. The dual roller chain from column to gearbox keeps the box in the rear steer position and eliminates snaking the steering shaft through the exhaust and other close areas. Not a problem with a small block but very crowded with a big hunk or iron like the caddy. The chain would wad the 3/4" steering shaft up like playdough and never feel the strain. Must be in perfect alignment and have an adjustment for tension. Trouble free for 200k+ miles. All the farm boys recognize the chain and sprocket setup cause the old balers, combines, thrashers(showing my age), etc., had them in many locations. Something different makes some leery but chains turn the cams in a Formula 1 engine 12 grand and twist cams in race engines that have 16 valves with 300# seat pressure each. As slow as a steering shaft is turned and probably 25#'s or so twist to the power steering box I don't worry.
Evan
| | | | | Joined: Aug 2007 Posts: 17 Apprentice | | Apprentice Joined: Aug 2007 Posts: 17 | Thanks Guys for your info to me on the Cad swap, sorry to be so long in thanks/reply but had to attend the loss of an old friend, been out of town. Regarding my moving the steering box to put my 327 in; I used a Camaro (or Nova ?) front frame clip which alievieated that problem. Not sure I want to use the Cad, seems not to be the optimum if your looking for more than torque (unless you spend a lot of money), thinkin BB Chevy - any inputs appreciated.
PBO | | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | The Cad engine is only a few pounds heavier than a SBC, and it develops enough torque you don't need high RPM. There are several hotrod parts available for the Caddy, also, things like roller rocker arms, camshafts, intake manifolds, etc. I'd pick it over the big block Chevy on weight alone. I'm about to build up a 54 Chevy pickup on a Nova front frame/S-10 rear frame setup, with a 500 Cad/Turbo 400 drivetrain. Jerry
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I can think of some advantages of the BB Chevy, including you can buy one new with modern EFI if your pockets are deep enough.
Another is related, in that even the first generation BB's are more common than the Cadillac, and both performance and standard replacement parts are easier to buy at your corner parts store.
I have a Cadillac 500/Turbo 400 combination sitting in my shop with every intention of installing it one of my old trucks someday. I also have a Chevy 454 and may put it in the project truck sitting in my shop right now.
They both have a place and neither of them will go in one of these trucks without some modifications.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Oil was $93.00 a barrel today... Otherwise I'd have gone in that direction.
~Jim
| | | | | Joined: Aug 2007 Posts: 17 Apprentice | | Apprentice Joined: Aug 2007 Posts: 17 | Sorry to be so long in reply, a couple of diversions kept me away from the site. No, I did not have to move the steering box when I put the 327 in the 52. You have probably long ago figured that out but wanted to close the loop. PBO | | |
