1 members (5 Window 9434), 68 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#829856 02/26/2012 5:25 AM
I was doing some research for disc brake setups on my '63 GMC useing the site search engine and came across some interesting info. If I followed everything correctly, it looks like you can take the suspension crossmember from a 73-87 pu and almost bolt it into the 63-66 Chev/GMC pu. This then allows you to use all the suspension components from the donor.
Have any of you used this setup yourself?
In such a khonstant state of khaos I dont know what project to work on first.
i don't know bout for that year i know it works well for the early 50s trucks provided you remove 1" from the center and shorten the A arms, but my 59 had the same track as a 68-80's truck so don't see why it wouldn't be possible
1937 1/2 ton
almost a bolt in you have to drill the frame for the idle arm and rework the steering shaft and where the box mounts to the frame
Thanks leonard, that was a big help. Now I have all the components for my '63 GMC. :-)
I did it on a 65 C10, 73-87 front end. Had to elonggate one hole in frame.
