7 members (Tinker5, chevy51truck, Gdads51, Hotrod Lincoln, Woodcmiami, 3800GUY, Bill Hanlon),
148
Mod | | | Forums66 Topics128,036 Posts1,055,458 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | I did a cylinder leak down test on my 261 today and the results were good. Every cylinder showed less than 10% leakage. On three different cylinders I could hear a very slight leak of air past the exhuast valve but those cylinders still showed less than 10 % loss.
So my question is seeing as this is the first leak down test I've done the motor passes right, even with the slight leak past the three exhaust valves seeing as all the cylinders show exceptable loss?
-mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Uh oh, 33 hits and no replies. Even WAG's are welcome. :>) Seeing as the motor ran so well for the previous owner it'll probably go in as is.
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I would be a little biased, but those numbers sound good. Run it. LOL Get it running and warm, then check the valve adjustment to make sure it's still okay.
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | Is the engine in regular service, or has it been sitting awhile? A leakdown test is only effective if the engine has been run recently, otherwise there can be minor leaks caused by rust buildup on the face of a valve that's been sitting open during storage. I'd say a 90% + reading is excellent. Once you get it installed and running, do a cylinder balance test where you short out one spark plug at a time and record the RPM drop and manifold vacuum drop. Jerry
| | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Jerry, Yes it has been running up until recently. Thanks for the balance test advice, I'll do that when the motor's in and thanks for the input in general.
-Mike-
| | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Roy,
I did have a couple of tight valves so I'm setting them all at three thousands over the recommended clearances until I can do that "warm" setting.
The leak tester is a new toy given to me by a friend, a dangerous tool in the hands of someone like me with limited knowlege. LOL
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Agree with all the previous Mike, especially that if getting the engine hot to do the test. I might add the even if your valves are hand lapped and seal perfectly and hold water you will still have some leakage past the rings, no cylinder seals perfectly. Cold the ring gap isn't closed up and you will have more leakage past the rings, warm and there will be a minimum of leakage. Also when the engine is running the combustion pressures force the ring out against the cylinder wall for a better seal so you will never get a perfect seal during a leak down test. As Jerry posted, a 90% reading would be excellent. 8-10% on a normally aspirated engine knocks it out of the ball park and variation of 4-5% cylinder to cylinder is normal, but even a 10% variation isn't anything to worry about unless your building an engine to run at Indy.
Denny Graham Sandwich, IL
Denny Graham Sadnwich, IL
Denny G Sandwich, IL
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | My "leakdown tester" is nothing but a pressure regulator installed in an air line. With the hose plugged off and no air flowing, adjust the pressure to 100 PSI, and then connect the coupler to a quick-connect fitting brazed into an old spark plug shell. If the pressure drops to 89 PSI, for instance, that's 11% leakage. Listening at the intake, exhaust, and oil filler for airflow will tell where the pressure is escaping. Bubbles in the radiator indicate a leaky head gasket or a cracked head. Jerry
| | | | | Joined: Mar 2011 Posts: 229 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 229 | i've done the same as Hotrod but i just adapted my compression tester to a quick connect for the compressor.
MO's 1951 chevy 3100 resto mod project
| | | | | Joined: Sep 2011 Posts: 1,451 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,451 | I did a cylinder leak down On three different cylinders I could hear a very slight leak of air past the exhuast valve
-mike- Mike, Got thinking about this part. Where are you listening, tail pipe, exhaust manifold off, etc. Is it possible that the air noise you are hearing is not comming out the exahust valve of the pressurized cylinder but out an open exhaust valve of another cylinder via the crankcase?
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Aug 2011 Posts: 835 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 835 | OK Denny, looks good. Now I'll show you mine. Here is the leak-down tester I made to diagnose a problem in the engine I rebuilt for my 1937 John Deere Model B tractor. I used an old sparkplug as an adapter. Turns out the plug shell (after busting out the porcelain) was exactly the right size to tap for the pipe. Lucked out. After all this discussion, I'm going to make an adapter for my stovebolt engine too. Anyway, thought this might be of interest. Leak down tester Kurt | | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | BC, I had the exhaust/intake manifold off the motor, I used a piece of rubber heater hose as a stethiscope and I was able to listen into the exhaust ports and intake ports individualy. I did make note of the air noise at the dipstick tube which from what I have learned is normal as all motor will lose some air to the crankcase past the rings. I listened at each manifold port when I did the test so was able to detrmine no air leak in any of the intake valves and three slight barely audable leaks from the exhuast which by the way were not adjacent to each other if this makes clearer what I did.
-Mike-
