0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | Howdy everyone. I have voluteered to assist Peggy with publishing the Tech Tips that have been submitted. As a part of the process I will be placing queries in the various forums looking for details and/or fact checking.
Today I'm looking for info on clutches and Bell Housings. A tip was submitted where the writer discussed installing a T-5 tranny. In his case he was adapting the transmission to replace a SM420. The bell housing and clutch he used were out of a 55 1st series, though he isn't sure if it was the orignal or had been swapped at some point. It had a 10 3/4 inch clutch with a 10 spline clutch disc.
What I'm trying to find out, is bell housing typical for AD trucks running the sm420? While I know that in earlier years the 10 3/4 clutch was only used on 1 tons (I think it had something to do with the torque tube design?)would later models use the 10 3/4 clutch as well?... Do lighter trucks with 9 or 10 in. disk still have the same 10 spline disk and bellhousing arrangments?
Any inputs will be appreciated.
Thanks | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They all use the same 10 spline disc & trans bolt pattern in that era. When you put in a T-5 you need a 14 spline disc. You canuse whatever pressure plat it came with. The last one I did I am useing the original S-10 9 in. clutch disc with the larger pressure plate. It is in my 56 with the 235 engine. It is working real good. I plan on putting in a V-8 engine this year & I will use a larger clutch. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I don't know if it helps but the bolt pattern that the T5 uses started in 1948 in trucks, 1955 in cars.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2008 Posts: 320 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2008 Posts: 320 | Thanks for the good info guys. When I work on these tech tips I want to make sure (to the extent I can) that they state years and models they may be applicable. Once it is finished, I'll post it here for review and inputs. | | |
