| | | Forums66 Topics128,049 Posts1,055,695 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#82937 09/14/2007 11:16 PM | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | i have a 54 235 and was wondering if this spin on filter kit would work well with my motor. http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2DG4985&N=700+115&autoview=sku
if not can you direct me to one that would?
another question i have is- is there some type of pressure regulator for these bypass filters that would cut flow to the filter if oil pressure drops below a certain point or is there no such thing.
thanks in advance! | | |
#82938 09/14/2007 11:21 PM | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | and of coarse i wouldn't use the relocation adapter, just the filter mount and hose and such. | | |
#82939 09/14/2007 11:24 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | No. That,s a relocation kit for full flow filters. You will need to get a used bypass filter & get a hose & fitting kit from one of the specialty suppliers. There is no pressure regulator but you can put a restrictor in the fitting comeing out of the oil gallery. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#82940 09/14/2007 11:27 PM | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | ok thanks,
i seen on some peoples trucks on here that they had a kit that was make for the bypass system and they said mentioned they got it from napa. anyone know if napa still sells it, or any other retailer. | | |
#82942 09/15/2007 12:09 AM | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | thats exactly what i was talking about, i seen that in another post when i searched this topic
what size fittings did you use and whats your oil pressure look like. | | |
#82943 09/15/2007 4:14 AM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | The illustration above is showing a full-flow filter relocation setup. Either on a modified 235 or 261. The 1/2" lines give it away. The bypass filter uses an 1/8 or 3/16" ID rubber line.
Unless you've had your engine modified during the rebuild process, you're pretty much restricted to using the stock GM cartridge filter with the small rubber lines. The stock bypass filtering system bleeds off a small percentage of oil from the gallery and after running it through the filter, dumps it back into the pan. The modified engine full-flow system, with 1/2" ID lines and a spin-on filter, pumps all of the oil directly to the filter and then back to the bearings. In a modified 235 the idle pressure stays up around 25 psi and 45 at speed. I discovered that by plugging the bypass filter holes on a non-modified 235, that I picked up 5-7 psi at idle. This causes me to question the value of running a bypass filter. Do a search as there is a wealth of good info on the oiling system. Hope this helps.
Dave | | |
#82944 09/15/2007 1:17 PM | Joined: Aug 2007 Posts: 610 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 610 | well ive been thinking about not even running a filter. my truck is going to be a cruiser and used at the most once a week. then ill just change the engine oil every 2k miles or so.
thanks for clearing things up. | | |
#82945 09/15/2007 1:39 PM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I just bought one of those adapters for my 54 from oriellys and i have asked if there would be any problem using it and the answer was no. but i am still worried because of some comments made before and in this post. ron HELP btw i hope flachevy3100 doesn't mind but these pictures are on his webshots. http://rides.webshots.com/album/557190450brdpqh?start=48
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#82946 09/15/2007 4:35 PM | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Hi Ron and Chris,
You've got to remember that my engine block has been drilled and plugged to convert it to the full-flow filteration system which uses the 1/2" oil hose. The bypass system found in a non-drilled engine, uses a 1/8" ID line that is available from most of the online suppliers specifically for bypass filter setups. Your stock block is threaded for 1/8"NPT fittings. The relocation spin-on filter mounts are all threaded for 1/2NPT fittings....you'd have to reduce down to 1/8NPT at the filter and fabricate your own hoses. This is doeable but I question the need for adding a spin-on filter with plumbing that is going to have to worm around your exhaust system. Remember, the bypass system filter only 10% of the oil flow at one time. My concern is the pressure loss to the bearings while you're running a bunch of plumbing to a filter that isn't even going to be optimized between oil changes.
I've proved that plugging the existing filter holes will improve your oil pressure by 5-7 pounds and find that I'd rather have good oil pressure to the engine bearings as opposed to having a filter than only marginally filters the oil. Changing the new modern oils every 2-3K is cheaper then replacing a set of bearings and a cam.
As for the second part of your question there is not any way of regulating the pressure bleed-off from the relocated filter on a stock bypass filter system on the 235 engine unless you plug it. Using the 3/4 X16 threaded mount with a FoMoCo filter which has a built-in bypass, you can maintain oil pressure if the filter becomes clogged in a modified full-flow system.
If it were mine I'd plug it, smile when I saw the improvement in the oil pressure and just enjoy the drive.
Dave | | |
#82947 09/15/2007 4:43 PM | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | What years did they go to the full flow system on the 235 and 261's? | | |
#82948 09/15/2007 4:48 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | Running a remote spin on setup as supplied by a FLAPS is indeed dangerous on a bypass type engine as the oil is directly diverted away from the bearings and returned to the pan. A remote spin on adapter that is designed for bypass use will have a plug right in the filter head with a small (1/32" in my case) hole to regulate flow and pressure. A spin on unit with a restrictor results in better pressure than the original bypass filter which has a "cost" of 5-7 p.s.i. as Dave points out.
Curt B.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#82949 09/16/2007 1:52 AM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 235 never had full flow, 261 started in '59-'62. I'm running a filter from a '60 261 (wish I'd got the engine, too, but it's long gone now). I've got it plumbed in with 1/4" steel brake line, bushed up to the 1/2"npt on the housing. Still set up as bypass. I carry around 35-40 psi at idle, up around 60 or so at cruising speeds. I'm also running a FilterMag on the housing, too.
Bill Burmeister | | |
#82950 09/17/2007 4:37 AM | Joined: Nov 2004 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 121 | If you had a restriction the same size as what the factory bypass filter had, why wouldn't it work to use the spin on filter? I could see a spin on filter being a lot easier to change and not nearly the mess. | | |
