8 members (2-Ton, Peggy M, TUTS 59, JW51, walter74, moparguy, NJC, 1 invisible),
175
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 26 | Anyone know where I can find drive shaft and related parts for this truck?
Thanks, Circle J Farm | | | | | Joined: Jan 2010 Posts: 37 New Guy | | New Guy Joined: Jan 2010 Posts: 37 | I had a 68 C50 or 60 (I forget). I was able to get universal joints @ napa. I doubt anyone will have a complete new driveshaft in stock, but around here we have Six States and they can make a driveshaft within a day or two. Just need all the basic measurements.
Good luck | | | | | Joined: Feb 2004 Posts: 29,780 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,780 | Check with any tractor-trailer repair shop. They should be able to refer you to a local driveline specialty shop. It's probable you will need to take some measurements and have one or more shafts made. Fortunately, commercial vehicle driveshafts are pretty generic- - -brand names don't have a lot to do with what's available. Jerry
| | | | | Joined: Mar 2011 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2011 Posts: 39 | http://www.4xshaft.com/Here you can order a custom drive shaft built to your specs they have a PDF that will tell you how to make all the proper measurements. | | | | | Joined: Nov 2009 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2009 Posts: 26 | Thanks to all. I will start taking apart this weekend. I'll let you know how I make out. | | |
