| | | Forums66 Topics128,068 Posts1,055,882 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2011 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 103 | I have a '48 big bolt I'm trying to re-wire. I have the "Chevrolet Truck Shop Manual" for 1948 through 1953. It has a wiring diagram but it's near impossible to read. Anyone know where I might find a better diagram? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Sep 2011 Posts: 814 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 814 | What I did was photocopy the diagram and blew it up to 200%. It's much better than what's in the book but still is a chore to read. If you have access to a photocopier you might try that.
1956 Chevy 3200
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | this one is quite good Bill | | | | | Joined: Nov 2011 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2011 Posts: 103 | Dads50, Thanks, I chose the pdf. With color added it's much more legible. A file I recognized and figured I could work with. A larger copy would be even more helpful but I don't know how to print one that is more than one page. I keep getting only the first part.
red58, Thanks, that's the one from Chev shop manual. When I try to print it I only get a small part. Ben | | |
