4 members (k2handyman, moparguy, dt235sd, Hotrod Lincoln), 71 guests, and 1 robot.
Topics128,049
Posts1,055,678
#828774 02/22/2012 7:13 PM
Best to do when hot ?
Putting new gasket in... Fluid has the appearance of having some moisture in it...
1954 Chevy 3104 3 Window Hydra-Matic in my family for over 60 Years
Once in a while you get shown the light in the strangest of places if you look at it right... "Scarlet Begonias" Grateful Dead 1974
Yes, as with a motor oil change, it will drain more thorough if warmed up first.
Craig
ODSS Lawman
ODSS Lawman
if there is moisture and its under cover by either the bed or indoors, check out the vent to make sure its not clogged.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
Sweet, the truck spent a lot of years with no bed on it... The moisture most likely got in through the vent... Will check it any way to be sure... Thanks...
