1 members (Forty9), 176 guests, and 0 robots.
Topics128,101
Posts1,056,180
Members48,436
#828351 02/21/2012 4:41 AM
I am cleaning the gas tank on a 51 chevy coupe.......I have the tank off the car and am using liquids to dissolve the 'stuff'. My problem is: I can't get any gas to run out of the fuel hook up on the tank, is there a no backflo valve inside the pick up tube or is it plugged....I have blown it out with compressed air but still no luck getting it to flo out......help!!!!!!!! Pat
You would need the tank pretty full to get it to flow out.
The pick up tube inside connects to the outlet fitting and then curves down to about the center of the tank. If you tip the tank with out much liquid in the tank, it flows away from the pick up end of the tube.
If you can blow through it it should be fine.
My Blog
thanks for the great news.......don't know what I would do without these threads.....probably not in the rebuilding old car stuff.......Pat
