| | | Forums66 Topics128,079 Posts1,055,941 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 10 New Guy | | New Guy Joined: Jan 2012 Posts: 10 | I am cleaning the gas tank on a 51 chevy coupe.......I have the tank off the car and am using liquids to dissolve the 'stuff'. My problem is: I can't get any gas to run out of the fuel hook up on the tank, is there a no backflo valve inside the pick up tube or is it plugged....I have blown it out with compressed air but still no luck getting it to flo out......help!!!!!!!! Pat | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You would need the tank pretty full to get it to flow out. The pick up tube inside connects to the outlet fitting and then curves down to about the center of the tank. If you tip the tank with out much liquid in the tank, it flows away from the pick up end of the tube. If you can blow through it it should be fine.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2012 Posts: 10 New Guy | | New Guy Joined: Jan 2012 Posts: 10 | thanks for the great news.......don't know what I would do without these threads.....probably not in the rebuilding old car stuff.......Pat | | |
