1 members (51sub), 128 guests, and 2 robots.
Topics128,125
Posts1,056,338
Members48,440
I've got the SS trim around the outside of the window opening. I've got the small clutch head screw out top inside.
Anyone take this off before? Tips?
Y
Y Offline
First, pull down @ the joint, then working toward the rear pull the stainless away from the opening and outward of the opening. Once you get the rear side off the rest should come out fairly easy. Remember the stainless is "pinched" onto the opening. Hope this helps.
many thanks..great advice and successful operation.
You can leave the stainless on if those are my doors
Dennis
