2 members (DadsFirstPickup, Rusted Nut), 78 guests, and 2 robots.
Topics128,075
Posts1,056,279
Members48,441
With the help of searching out previous posts on installing door hinge springs, I believe I have them installed correctly.
hinge photo
Now how do I get get them to go into the pillar pocket? I think they have to be in the open position, but with the springs installed I can't put enough force on the springs to get it open. What's the trick?
I think I'll call it a night and try again in the morning?
Dave
www.fallenherosdreamride.org
all give some
MY SON GAVE ALL
The fallen hero's dream ride is a 1951 Chevrolet 3100 with original 216
In memory of LCpl Phillip Vinnedge USMC KIA 10/13/2010 Afghanistan
You do have the springs installed correctly and you are also correct that they have to be in the open position in order to slip into the hinge pocket. I mounted the part of the hinge that doesn't show (the very back strap part)in a vice and it opened up easily. It is then a tight fit, but it should go in fine.
Huck,
Thanks. I had had it in the vice. You inspired me to just get more leverage and put more pressure on it. Hinges are now in place.
Dave
all give some
MY SON GAVE ALL
