6 members (Rusted Nut, Lightholder's Dad, Bill Hanlon, Hotrod Lincoln, Buckeye998, 1 invisible), 87 guests, and 3 robots.
Topics128,091
Posts1,056,393
Members48,442
1 Offline
So I have a 235 that I picked up and am trying to decode the numbers.
The stamp pad at the distributor is Fo4I8A
is this just a serial number, or does it mean someting else/also?
Also, there are some other numbers on the head B55-848
850
The casting code for the head says its a 1956 head but what do these other numbers mean? Thanks in advance.
Trombones Totem Poles And Old Trucks!
I think the FxxxxA means a standard 235 engine from Flint, MI in a passenger car with a manual transmission. The particular year is not designated by that code.
The o after the F is not what would be expected. Maybe someone can post an explanation/correction?
The date casting codes for block and head are on this page.
