1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | I've got a 52 Chevy truck, with a rebuilt 216 engine. It starts fine when cold, but when warm, it won't start, nor fire. Any ideas what's going on would be appreciated. Bob | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Are you saying it does not crank over when warm, or it cranks with out starting?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | It cranks without starting. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | One last question. Is it 6 or been converted to 12 volts?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | Hey Tim, thanks for the response. Tomorrow I'm off to buy new cables. Bob | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | If your coil is marginal, the lower voltage when cranking can make the difference between starting and not starting. Here is a way to check for this problem. Disconnect the power feed to the coil and hook it up to a battery charger. If it starts quickly under those circumstances then you know what the problem is.
Also, on some the carburetor percolates a little. The technique for that condition is to gently put the gas to the floor, leave it there for about a minute and then without moving it, try starting it again. This requires both feet! | | | | | Joined: Apr 2011 Posts: 85 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 85 | Thanks for the reply. I've put a new coil on the truck. Iwill give the starting technique you mentioned a try. Bob | | | | | Joined: Apr 2009 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2009 Posts: 47 | I remember in shop class a long time ago, the teacher said the points need to come off the negative side of the coil. If not you can have the same problem your talking about. Wont start when warm. Dont know? | | |
