3 members (DadsFirstPickup, Bill Hanlon, 1 invisible), 147 guests, and 5 robots.
Topics128,108
Posts1,056,231
Members48,436
#827671 02/19/2012 5:29 AM
I forgot to ask, do I need to do anything to run pump gas in my 'bolt?
Tom
abxtc #827691 02/19/2012 6:16 AM
Do you mean 87 octane E10 fuel???
Just pump it in and drive it.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
I'm not sure why you would be asking such a question. I am pretty sure there is more to this question than what was asked. But you have to put it in the tank. If you leave it in the gas station you won't get very far.
Maybe a shop manual to figure out where your gas tank is first? :-)
Idk. Must be early. I just cannot understand the question. wink
Saint #827738 02/19/2012 2:32 PM
Ex Hall Monitor
Ex Hall Monitor
He may be asking if it's safe to run unleaded. The answer to that is yes, it's safe.
Saint #827741 02/19/2012 2:35 PM
Tom,
Do not let the folks scare you off from asking questions. However, a little information about your concerns would get you better answers.
Are you worried about dirty gas tank or dirty fuel lines or dried out carburetor?
Are you worried about octane or non-leaded gas or ethonal in the gas?
Denny's response is most likely all you need to know.
You guys aren't using lead additive?
Nope. Dump it in from the pump, and put the peddle to the metal.
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
lunchbox #827894 02/19/2012 10:06 PM
If I ever am lucky enough to find a 1964 Ford Custom with the 390 Thunderbird Police Interceptor package (like the one my Mom had when her 4 boys learned how to drive), I would be looking for a lead additive, I think.
these engines don't really produce enough combustion chamber heat to really hurt much. They only have 5.5-1 or 6.5-1 compression. (depending on which year you have) which is one of the reasons you only get 15-17 MPG out of one.
No kidding? Guess I can start using the money from lead additive savings for more parts!
Even the 8.25 compression ratio 235 would most likely not be harmed by lead free gas, unless in an a continuous high revving situation.
12K now on the valve job and never put anything in the '50, 216 but Marathon 87 octane
e10. Never could get it to ping no matter how far I advanced it and out of curiosity I've
advanced it till the starter wouldn't turn it over.
DG
Denny G
Sandwich, IL
abxtc #827998 02/20/2012 3:05 AM
Oops! I guess that was pretty vague just asking about the gas! I was heading toward not having lead in the gas anymore, did I need differant valves, hardened seats, etc.
Thanks for pointing the error of my ways!
Tom
